How can I calculate Kilowatt Hours from:
Complex Power = 1,5 kVA
Electrical current consumption = 10 A
It's three-phase electric power.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityHow can I calculate Kilowatt Hours from:
You can't. Knowing only the magnitude of the voltage and current does not tell you real power. To get that, you need the average of the instantaneous product of voltage and current. If both are sines, then power is the VA value times the cosine of the phase angle between voltage and current.
If it's a 1kVA 3-phase system (500VA per phase) at a current of 10A, then the supply voltage is 50V. That is all that can be said. It tells you nothing about how much real power is being consumed.
I could add that I have never heard of a 3-phase supply voltage of 50V but that is irrelevant
