I am studying this SCR relaxation oscillator and I cannot predict when it oscillates and when it does not.
The idea seems simple: as soon as the cathode voltage drops below SCR's gate trigger voltage, SCR turns on and the capacitor should discharge through the SCR, and it would rise the cathode voltage, and it would decrease the SCR a-k current. As soon as the current drops below SCR's holding current, the SCR should turn off, and the cycle should repeat.
But when I simulate this circuit it oscillates only with a certain very narrow set of parameters. For instance, it stops oscillating if I change R3 to 5 or 3 Ohm, if I change C1 to 1uF, if I change R1 to 8 or 10 Ohm, if I change R2 to 41 or 48 Ohm.
How can it be explained that this circuit stops oscillating when its parameters are changed so little? How can I predict without a simulation if the circuit oscillates or not?
