I have a circuit board that has come out of android TFT Car Display. I would like to know the part number of the small SOT23-5 integrated circuit chip that is on this board. I would really appreciate if anyone could help me identify this part or link from where I can buy this chip. The chip reads has 9HH or D9HH.
  • \$\begingroup\$ Tip: Edit and add the pin count and part number into your question title. Someone might recognise it there. \$\endgroup\$
    – Transistor
    Commented Aug 25 at 17:17
    \$\begingroup\$ This question is identical to: Identifying SMD IC chip. If you have additional information related to your original question, use the "edit" button to add the information there. It was "closed" in order to allow you to improve it before people try to answer it. Do not create a duplicate question. \$\endgroup\$
    – Dave Tweed
    Commented Aug 25 at 17:27
  • \$\begingroup\$ You say the marking is 9HH in your question, but there is clearly something written in front. Is it logo? Please take a close-up picture. \$\endgroup\$
    – nanash1
    Commented Aug 25 at 17:49
    \$\begingroup\$ When I looked at the picture originally thought the marking was HH6, rather than 9HH. Not sure which is the "correct" orientation - The ultimate SMD marking codes database has some SOT23-5 devices with both markings HH6 and 9HH. \$\endgroup\$ Commented Aug 25 at 17:52
    \$\begingroup\$ Looks like |09HH or |D9HH where the | is the pin 1 marker. \$\endgroup\$ Commented Aug 25 at 19:19
Looks like MPS MP1540D, a 1.3MHz switching regulator boost converter.
This would have marking D9xx where the last two digits are a date code.
Pinout of IC and Marking
The inductors appears to connect between pins 1 and 5, with pin 2 going to what appears to be the GND plane. These match the typical application from the linked datasheet.
Looking at images on well known Chinese marketplaces the marking looks identical.
From the link in the comments by @vivier, the HH would represent week 15 of 2017.
  • \$\begingroup\$ The nearby components D25 and L14 make sense for a boost converter. \$\endgroup\$ Commented Aug 25 at 19:42
  • \$\begingroup\$ Thanks for all of you who have contributed in finding this chip.. truly appreciate it.. i will order this part and give it a try... will keep you posted if it works... \$\endgroup\$ Commented Aug 26 at 17:01
