I was searching different circuits to produce sinusoidal waves and came across one that seems simple but I do not understand how it works. It has the usual band pass filter (in this case it was a Wien bridge) and an amplification stage, which is the one I do not know how it works.
In the image I have shown the circuit and a simulation in Proteus. The zener has a zener voltage of 2.2 V.
I understand that C3 and C4 are decoupling capacitors and that those set the lower cutoff of the gain plot. R4 and R7 set the bias for Q1. R5 and RV1 set the gain. And Q1 and Q2 are similar to a Sziklai Pair, but with R3 and R6+zener between the collector of Q2 and the emitter of Q1.
How does this circuit work?
