Another simulation of the circuit. It also says no voltage or current will go through it.
Why is this happening? Isn't electricity supposed to take all possible paths? Is solving for this circuit's equivalent resistance possible? Thank you in advance!
    \$\begingroup\$ in reality, the voltage would be near zero, but not zero, because of the resistance of the wire \$\endgroup\$
    – jsotola
    Commented Aug 27 at 6:22
  • \$\begingroup\$ Nice 3D picture. +1 for the original idea! \$\endgroup\$ Commented Aug 27 at 10:42
It takes all possible paths, but in this case it is not a possible path.
In your circuit; both ends of the resistor are connected to a same node. It means the resistor has 0V over it. And from Ohm's law we know that 0V over a resistor means 0A.
  • \$\begingroup\$ I think that I understand what you mean. So if the wire wasn't ideal and had a resistance, then would that resistor have some current? \$\endgroup\$
    – RReddy
    Commented Aug 27 at 4:14
  • \$\begingroup\$ @RReddy Yes; a practical non-superconducting wire would have non-zero resistance, thus there would be non-zero voltage over the resistor and non-zero current through it. But in practice you can ignore it in most circuits. In some sensitive circuits, you might not be able to ignore it, and in the most sensitive circuits, even the effect of the junction between wire and resistor must be considered. These real world effects are ignored by your simulator. \$\endgroup\$
    – Justme
    Commented Aug 27 at 4:22
    \$\begingroup\$ @RReddy yes.Change the wire to a 200-ohm resistor and see what happens. Then replace it with 20 ohms, then 2 ohms, then 0.2 ohms. Now extrapolate to 0 ohms :) \$\endgroup\$
    – hobbs
    Commented Aug 27 at 4:48
