I am trying to determine the Norton current between the terminals a and b of the network shown below. \$Z_1\$, \$Z_2\$, \$Z_3\$ and \$Z_4\$ could be resistors, capacitors or inductors.
To do so, I have shorted terminals a and b (see blue line). Then, I applied the mesh-current method, where I defined currents \$I_A\$, \$I_B\$ and \$I_N\$ as shown in red.
The matrix equation I obtained is:
$$ \begin{bmatrix}1&0&0\\-(Z_1+Z_2)&Z_1 + Z_2 + Z_4 & -Z_4 \\ -Z_3 & -Z_4 & Z_3 + Z_4\end{bmatrix} \begin{bmatrix} I_A \\ I_B \\ I_N\end{bmatrix} = \begin{bmatrix} I_S \\ V_S \\ 0\end{bmatrix} $$ By solving this equation, I can find \$I_N\$.
However, I am uncertain whether this approach is correct. Specifically, I am concerned that shorting terminals a and b might effectively short-circuit all the elements ( \$Z_1\$, \$Z_2\$, \$Z_3\$ and \$Z_4\$), potentially creating a mesh with no resistance (illustrated in blue below).
If this is the case, then the Norton current \$I_N\$ might simply be equal to \$I_S\$.
Which of the two reasonings is the correct one?
Thank you very much!
Z3+(Z1+Z2)||Z4
. \$\endgroup\$
