I am interested to use an opamp with an exact 3 dB rolloff at 320 kHz for an sinewave (voltage swing) from -10 to +10 V.
I think I need to do this using some resistors and capacitors on the feedback path.
I tried to simulate this using LTspice to find the values, but my simulation does not seems to be correctly set up.
What is missing from the simulation circuit or the directive?
