I just got my first 4 layer newly assembled board from PCBway.
When USB cable is connected, the board is not powering on.
When I checked the vbus it's showing 0.45v. After this I checked the MOSFET q1 and q2 and they seem to be damaged. How could this have happened with just powering the board for the first time?
Because this board is not getting powered I can't flash the firmware ofc
On the PCB, I soldered a wire directly to vbus to check the voltage. From the source itself it's now working.
Another question: Is it ok to just bypass the q1 and q2 and directly connect a jumper from micro USB vbus to mcu usb_vbus?
Also, when I connected a ST-Link probe to the JTAG, it didn't detect although it is Renesas board. So I wasn't that hopeful about my punctuation. Are there any other ways to get the MCU detected by pc?
Once I can get power through USB then only after pulling down MD can I flash the firmware (until then I can't do anything).
Please suggest something should I desolder the USB board, and/or resolder?
To me right now USB port seems faulty but it's a new board and ports like this shouldn't get damaged easily in first boot. Another thing is that I can power the board through can port after which everwhere else voltage seems fine but then i still can't flash firmware without usb so please someone suggest something this already got me panicing.[sic]
Other this I suspect maybe I got a wrong footprint and soldered the port completely wrong? But then the ratsnest and ERC checks would have shown this.
