Figure: OP amp filter circuit.
This is a problem from a book "Microelectronic circuits",7e by Sedra and smith, OUP.
The two op amp circuit is called an Antoniou Inductance circuit as it emulates an inductance and this circuit along with a capacitor and a resistor form a LCR circuit which is used for various applications. A difference is that the branch with capacitor, second from left has a resistance in place and the last branch with a resistor has a capacitance in place in the original circuit. I had obtained the resistor has 10 KΩ for an output sinusoidal signal of 1 kHz. When I tried to find the output voltage, it seemed that the voltage at \$V_2\$ is 0.7V looking at the diodes connected to \$V_2\$ and GND. Where is the output voltage taken? is it at \$V_2\$ or somewhere else? if its at \$V_2\$, it should be 0.7v Peak. How does one obtain the output voltage? A derivation is appreciated.
Problem:
Using C = 16nF, find the value of R such that the circuit in the figure produces 1 kHz sine wave. If the diode drop is 0.7V, find the peak-to-peak amplitude of output sine waves. (Hint: A square wave with peak-to-peak amplitude of V volts has a fundamental frequency component of \$\frac{4V}{π}\$ volts peak-to-peak amplitude)
Answers given: 10kΩ, 3.6V
Reference: Microelectronic circuits - Theory and applications, 7e, Sedra and smith, page 1082, OUP india.
