Please refer to the following drowing:
Imagine from utility to the electrical outlet we receive line, neutral and earth as shown above in Figure 1. This is connected to a device such as a power supply with a load R inside a chassis. F depicts the fuse of the device.
If we swap the power plug to the outlet or socket, we will obtain Figure 2.
Does that mean the device fuse will not work in this case?
When making a power plug like the one below, does it matter which pin is connected to line and which pin is to neutral?
