Trying to identify the part number for this connector, the connector has the marking AMP 2 on its housing, from this i would assume it is made by Amphenol !
The pin pitch is 4.2mm, and its from a Closomat Bidet PCB.
Front
Top
Side
It's a custom derivative of a Molex Mini Fit JR connector or a TE VAL-U-LOK connector.
The standard Molex connector looks like this. Note that the polarization inside each cavity looks different.
The standard TE connector looks like this. Again, note that the polarization inside each cavity looks different.
No. AMP and Amphenol are different companies. AMP is now owned by TE connectivity.
    \$\begingroup\$ I did wonder if this was custom made connector as i couldn't find that polarization in all the similar connectors. Looks like i will also need to change the connector plug to match the standard Molex, thanks for your help. \$\endgroup\$ Commented Sep 8 at 20:55
    \$\begingroup\$ I think you can also carefully shave the plastic down with a knife. \$\endgroup\$ Commented Sep 11 at 0:58
