I am working on interfacing 16X2 lcd in 4bit mode with pic18f4550.The higher 4 bits (D4,D5,D6,D7) are connected to PORTA1,A2,A3,A4 , pin RAO as RS, RE2 as RW, RE3 as RE3. i am struck with below code which displays nothing .The below code compiles without any error ,but display nothing (assume no mistake in my hardware connection)? /* * File: main.c * Author: tamil * * Created on June 5, 2013, 11:32 PM */ #include
#pragma config FOSC = HS // to select external osc
// CPU System Clock Postscaler:
// [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2 = 48 MHz CPU Clock]
#pragma config CPUDIV = OSC1_PLL2
#pragma config PWRT = ON // 62 ms waiting at start
#pragma config BOR = ON // Brown our Reset enabled (IMPORTANT!!!)
#pragma config BORV = 2 // Reset level = 2,7 V
#pragma config WDT = OFF // watch dog timer off
#pragma config DEBUG = ON,LVP = OFF // debugger on , as per pickit3
#pragma config PBADEN = OFF //PORTB<4:0> pins are configured as digital I/O on Reset
#pragma config MCLRE = ON //MCLR pin enabled; RE3 input pin disabled
//lvp should be off
#define rs LATAbits.LATA0
#define rw LATEbits.LATE1
#define en LATEbits.LATE2
#define lcdport LATA
void Delay_ms(int ms)
int i,j=0;
for(i=0;i<ms;i++)
for(j=0;j<165;j++);
void lcdcmd(unsigned char cmdout)
lcdport=(lcdport |(cmdout << 1)); //Send command to lcdport=PORTB
rs = 0;
rw = 0;
en = 1;
Delay_ms(1);
en = 0;
void lcddata(unsigned char dataout)
lcdport=(lcdport | (dataout << 1)); //Send data to lcdport=PORTB
rs=1;
rw=0;
en=1;
Delay_ms(1);
en=0;
void dis_data(unsigned char data_value)
unsigned char data_value1;
data_value1=(data_value&0xF0);
lcddata(data_value1);
data_value1=((data_value<<4)&0xF0);
void dis_cmd(unsigned char cmd_value)
unsigned char cmd_value1;
cmd_value1 = (cmd_value & 0xF0); // Mask lower nibble because RB4-RB7 pins are being used
lcdcmd(cmd_value1); // Send to LCD
cmd_value1 = ((cmd_value<<4) & 0xF0); // Shift 4-bit and mask
void lcd_ini()
dis_cmd(0x02);
Delay_ms(200);// To initialize LCD in 4-bit mode.
dis_cmd(0x28);
Delay_ms(200);// To initialize LCD in 2 lines, 5x7 dots and 4bit mode.
dis_cmd(0x0C);
Delay_ms(200);
dis_cmd(0x06);
Delay_ms(200);
dis_cmd(0x80);
Delay_ms(200);
void main ()
unsigned char data[]="tamil";
unsigned int x =8;
//unsigned int y = 1;
//unsigned int i=0;
ADCON1=15; // to configure all analog pins as digital i/o
TRISA = 0; // to config port A as o/p
TRISE = 0;// to make it as o/p
lcd_ini();
// LCD initialization
while(data[i]!='\0')
dis_data(data[i]);
Delay_ms(200);
i++;
