Hello i am trying to have the same audio play on two usb earphones, i have tryed multiple adapters but nothing work, the software force me to choose between one of them, while failing to bypass this issue from a software perspective (i know windows can do this same result with an app, VoiceMeter, android refuse to do the same)
i am trying to make a hardware solution can a parallel usb adapter work like this ? if yes, should i use some resistors to protect it ? where and how much mOhm ?
