I realise similar questions have been asked in the past about automating capacitive touches, but I'm aiming to put this into practise with a simple circuit.
I want to be able to simulate / automate the press of a capacitive touch button on a tumble dryer. I want to do this without opening up or modifying any of the existing circuitry.
I've tested placing some aluminium foil on the button and either touching it or running a wire from it to ground (metal sink) and both work in activating it. I want to take this to the next step now and build a circuit to automate this.
I have designed what I think is the circuit to achieve this, however my electronics experience is extremely rusty going back 30 years to high school physics and some recent Googling on transistors and capacitive touch.
Before I go out and buy the components, I'm looking for some input as to whether I'm overlooking anything.
Proposed circuit diagram:
In the diagram, L1 is just an indicator to show me the "press", R1 is to bring the current down to about 20ma for the LED (with ~1.7V across the LED and ~0.7V across the transistor), enough to active the transistor but to keep it below the collector voltage (potential).
I've read that the potential on a capacitive touch button is between 1.8V to 5V (so I'm estimating somewhere in the middle) and R2 is just to place some load between the button and ground so there's no short to ground.
My belief is that when the GP26 is activated at 3.3V, the LED will light up and the 0.7V on the transistor will then allow the flow from the collector to emitter (i.e. ground) which would result in the button sensing a change in capacitance and activating a "press".
Am I missing anything?
tumble dryer
itself has a capacitive touch button on it that you want to control using an MCU rather than a manual touch by hand and that you've done a little bit of testing, finding that "grounding" a certain point appears to work. And you want to make a circuit for the MCU that both turns on an LED and also activates this switch? And you will be sharing the MCU ground with the dryer's ground somehow? \$\endgroup\$
