I have a home in a countryside where grid power cuts off very often (3-5 times per week) for a few hours, especially in a winter time.
I came up an idea to make a backup system that will automatically or manually turns on when grid power goes out. (Currently I'm using portable power generator.)
I don't have electrical engineering degree but I know basic concepts and I've build and rebuilt a few EV bikes an scooters a few years ago. (I've software engineer background.)
The goal is to have 7-10 kWh energy backup system that can provide at least 220 V, 16 A. I prefer to have 220 V, 32 A power to run entire home appliances on it.
1. Battery: For batteries I am going to use EV or HEV battery Li-ion battery cells. (Ford fusion, Chevrolet volt ... ) because they are relatively cheap in my area. I can build 48 V, 96 V, or 220 V battery packs myself.
2. Charging: Currently I can accept charging the batteries with grid power (220 V) when it is available.
3. Using the power: As I said, 16 A - 32 A will be enough to run my house off grid. It will be good If I would have auto switcher between grid/backup system but I can do it manually.
My Idea:
I have an idea to buy used or broken APC UPS and modify it for my needs and change battery with my bigger battery pack.
The question is how deeply I have to modify the ups system to use/charge bigger battery pack? Will it be able to provide power of a long period of time? If so, which model UPS should I look up?
If using the UPS system is a bad idea, I have to purchase separately battery chargers, control module, inverter and etc... In this case can you suggest any components?
