I am wanting to try some experiments to see how much power can be generated using various magnets and coils, but my understanding is the voltage is positive as the magnet approaches the coil and negative as the magnet passes and moves away from the coil. Can the negative power be converted to positive?
I don't want to invert all power generation, just the negative part.
Perhaps this is possible by using an AC to DC converter, or voltage inverter? Or any other ideas?
    \$\begingroup\$ What do you mean by negative power? If you have a generator and a load, you can say that your generator has positive sign and your load negative to denote power flows. But here I doubt that's what you mean. Do you mean negative voltage? \$\endgroup\$
    – winny
    Commented Oct 7 at 8:47
  • \$\begingroup\$ Yes, thank you for your clarification - I mean negative voltage. When a magnet moves back and forth the negative and positive swap, so a volt meter reads positive, negative, positive, etc.. I would like to clean that power generation so the output is always positive and useable. Thanks again. \$\endgroup\$ Commented Nov 1 at 0:18
You need a full wave rectifier.
Unfortunately a 'typical' coil with 'typical' magnet strengths and speeds will produce a fairly low voltage, so ordinary rectifier diodes will eat most of your generated voltage.
The diagram on the left shows the standard full bridge rectifier. With the silicon diodes shown, you'll need at least 2 diodes drop of somewhere around 1.2 V generated before significant current is available at the outputs. With schottky diodes, the excess voltage needed drops to around 0.6 V or so. 1
The diagram on the right is a 'voltage doubler' circuit, that only requires one diode drop extra from the generating coil before it provides useful output. With schottky diodes only 0.3 V is needed. Size the capacitors according to your load, there's only 1 uF shown there as it's the default, you may want capacitors in the 1000's of uF.
To scrape a few extra 10's of mV, note that power diodes will generally have a lower voltage drop at any given current than small signal diodes.
It is possible to get lower voltage drop, approaching zero, if you use actively controlled FETs, but it gets complicated, and needs an external power source to get it going if the purpose is to handle very low input voltages.
In a DC permanent magnet generator, the 'rectification' is done by switches, cleverly sequenced by being mounted on the same shaft as the coils, in an arrangement called a commutator
1 Diodes actually conduct at any voltage, but due to the exponential relationship between voltage and current, you don't get 'useful' levels of current, let's say in the order of a mA, before you get to the suggested diode voltages. You can read lower voltage drops if your only load is the voltage input of a DMM.
