I am new to this kind of communication. I am able to send command from PC to AT90USB1287 microcontroller as well as able to get response using USB communication. Now i have connected another microcontroller(ATmega32) to this board via USART communication. I am trying to send command from PC to this board. Both controllers have different commands. So i have created an array containing both controllers commands in AT90USB1287 controller. My concept is compare the incoming command from PC with all commands in array based on result i am trying to send commands to ATmega32 controller using USART. I have the code as shown below.
#include <90usb1287.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <ctype.h>
#include <interface.h>
#include <uart_drv.h>
#define CMD_SIZE 57
#define USB_CMD_SIZE 52
flash unsigned char * flash cmdList[CMD_SIZE] = {
"", // [0] no com
"INFO", // [1] Displayes version date etc.
"SET", // [2] Reset CPU
"boot", // [3] Goto boot
"UMP", // [4] Display manual debug info
"AUTO", // [5] Start automatic scanning
"STRP", // [6] Stop scanning
"STAF", // [7] Set start frequency
"STOF", // [8] Set stop frequency
"RES", // [9] Display manual debug info
"RATES", // [10] Display manual debug info
"GAINAD", // [11] Set gain
"SCANSD", // [12] Start custom scan
"SETUP", // [13] Display manual scan setup info
"TEMP", // [14] Set temperature (Celsius)
"COM", // [52] no com
"PINF", // [53] Displays version date etc.
"PSCAN", // [54]
"PWGF", // [55]
"PADC" // [56] Clear Flash memmory (stopLog)
unsigned char SerIn[SIBUFSIZE]; // Input buffer (raw data)
unsigned char RxCnt; // Location of next byte to be written
unsigned char RdCnt; // Location of next byte to be read
unsigned char BufCnt; // Size of unread contents in ring buffer
unsigned char CompIndex; // Index in Copmare array
unsigned char Compare[COMPBUFSIZE]; // Command string tokenizer
unsigned char Uart_CompIndex; // Index in Copmare array
unsigned char Command; // Current Command is executed
unsigned int Param; // Parameter used in command
float Param2; // Optional (second) parameter used in command
unsigned long Param3; // Optional (third) parameter in command
extern unsigned char Plot;
unsigned char Step;
// USART1 Receiver interrupt service routine
interrupt [USART1_RXC] void usart1_rx_isr(void){
char status,data;
status=UCSR1A;
data=UDR1;
printf("%c", data);
// USB Receive
void catchString(void){
while(UEBCLX){
if(++BufCnt >= SIBUFSIZE){ // Increment & check for buffer overflow
BufCnt = SIBUFSIZE-1; // Set to max value
return; // Skip char
}else{ // Else: if buffer ok
if(++RxCnt >= SIBUFSIZE) RxCnt = 0;// Increment read counter, if 10 -> 0 (max 9)
SerIn[RxCnt] = UEDATX; // Write to SBUF (load the transmit register)
// Read from ringbuffer
char getcharb(void){
if(BufCnt){ // If anything
BufCnt--; // Decrement buffer counter
if(++RdCnt >= SIBUFSIZE) RdCnt = 0; // Increment read counter, if 10 -> 0 (max 9)
return SerIn[RdCnt]; // Read from SBUF (access receive register)
return 0;
void getcom(void){
unsigned char c;
// Read from ring-buffer and fill in Compare buffer
while(BufCnt){
c = getcharb();
if(CompIndex >= COMPBUFSIZE) CompIndex = 0;
// Analyze char
if(c == '#'){
CompIndex = 0;
}else if(c == '\r'){
Compare[CompIndex]='\0';
break;
}else if(c == '\n'){
// Do nothing (ignore)
}else if(c == 8){
if(CompIndex) CompIndex--;
}else if(c == 9){ // Horizontal TAB
help(); // Write out cmds
}else if(c == 27){ // ESC button
Command = 0;// Stop current command
Param = 0; // Clear argument
Plot = 0; // Stop plotting
Step = 0;
}else{
Compare[CompIndex++]=c;
}if(!BufCnt) return;
}CompIndex=0;
c = 1;
while(c<CMD_SIZE){ // For each command
if(strncmpf(Compare,cmdList[c],strlenf(cmdList[c])) == 0) break;
c++;
if(c> USB_CMD_SIZE){ // this is for ATmega32
Command = c;
if(isdigit(Compare[strlenf(cmdList[c])])){
Param = atoi(&Compare[strlenf(cmdList[c])]);
c = strpos(Compare,':');
if(c > 0){
Param2 = atof(&Compare[c+1]);
c = strrpos(Compare,':');
if(c > strpos(Compare,':')) Param3 = atol(&Compare[c+1]);
else Param3 = 0;
}else{
Param2 = 0;
Param3 = 0;
}else{
Param = 0;
Param2 = 0;
Param3 = 0;
uart_putchar(Compare);
//printf("@%s\r\n",&Compare); //Ack command
if(c<USB_CMD_SIZE){ //If match on normal cmnd in usb
Command = c;
if(c > 0){
else Param3 = 0;
}else{
Param2 = 0;
Param3 = 0;
}else{
Param = 0;
Param2 = 0;
Param3 = 0;
}else{
if(c>CMD_SIZE-1){ // If match on normal commands
printf("&E;1;\r\n"); // Command not found
printf("->Unknown command: 's'\r\n",&Compare); // If no match
Command = 0;
Param = 0;
Param2 = 0;
Param3 = 0;
in the above code i am able to get response from USB controller but not from ATmega32A. I am checking the index is >52(USB_CMD_SIZE) then send to ATmega32 otherwise send to USB)=1287.
I am getting error in this line
I have the function for uart_putchar like this.
void uart_putchar (char ch)
while(!Uart_tx_ready());
Uart_set_tx_busy(); // Set Busy flag before sending (always)
Uart_send_byte(ch);
return;
even i tried like this
uart_puts(Compare);
for that i have written like this
void uart_puts(const char *s)
while(*s)
uart_putchar(*s++);
// printf("*");
But nothing is working for me. Can anyone help me how to fix this? Do I need any conversion here? If so, please help me with an example.
When i use this code then i am able to get response from atmega32 but what was the problem is this code is sending all commands to both controllers so at that time i have problem so i am trying the above one.
void getcom(void){
unsigned char c;
while(BufCnt){ // while unread contents in ring-buffer
c = getcharb(); // fetch next byte
if(CompIndex >= COMPBUFSIZE) CompIndex = 0;// overflow protection
// Analyze char
if(c == '#'){ // Manual start
CompIndex = 0;
uart_putchar(c);
}else if(c == '\r'){ // CR continue (end of cmd without argument)
Compare[CompIndex]='\0'; // fill in end character of comp string
uart_putchar(c);
break; // possible valid cmd received -> check out
}else if(c == '\n'){ // New line (ignore)
}else if(c == 8){ // Backspace
if(CompIndex) CompIndex--; // decrement index
uart_putchar(c);
uart_putchar(c);
Command = 0; // Stop current command
uart_putchar(c);
Step = 0;
}else{
Compare[CompIndex++]=c; // Default action: Store character
uart_putchar(c);
}if(!BufCnt) return; // if no more data to read -> exit
}CompIndex=0; // reset, ready for next command
c = 1;
c++;
if(c<USB_CMD_SIZE){ // If match on normal commands
Command = c;
if(c > 0){
else Param3 = 0;
}else{
Param2 = 0;
Param3 = 0;
}else{
Param = 0;
Param2 = 0;
Param3 = 0;
}else{
// printf("&E;1;\r\n"); // Command not found
// printf("->Unknown command: '%s'\r\n",&Compare); // If no match
Command = 0;
Param = 0;
Param2 = 0;
Param3 = 0;
this code is sending each and every character to both controllers.
In Compare i have the command like "PSCAN".
this line printing like
@PSCAN
Compare
, what does it contain? Could you show more code? \$\endgroup\$ – abdullah kahraman Jun 14 '13 at 13:04Compare
is not initialized with any values and is only filled whenCompIndex >= COMPBUFSIZE
. Try assigning some dummy values to it, in the initialization, maybe. But I am not sure if this is the problem. \$\endgroup\$ – abdullah kahraman Jun 14 '13 at 13:54
