I have a dual output sensor connected to two analog inputs on a controller.
The main output of the sensor works from 0.5 to 4.5 V DC and the other output is inverted such that it works from 4.5 to 0.5
Evidence from the field indicates one of the two sensor outputs will deviate from the other for short periods of time, that become longer during the operation period. The sensor manufacturer reports the returned sensors work correctly.
The field reports the same sensor output is usually the problem, but I have not found out if it is the normal or inverted output yet.
The controller’s data sheet says “the input impedance for the analog inputs is 200-250 kΩ”
The sensor’s datasheet says “the load resistance is 10 kΩ minimum (resistive to GND)”
I believe this is saying the input impedance for the analog input is too low for direct use with the sensor.
I admit a bit of ignorance regarding input impedance versus load resistance.
I am thinking something is triggering the sensor output to oscillate which could look like a deviation, the oscillation causes heating which causes the oscillation to get worse over the operating period.
The controller input which is reporting the deviation is filtered (somehow), so it is possible a high-speed oscillation is filtered out until the sensor output started having heating problems.
