It really depends what you mean when you think them as jumpers.
There are electrical uses and physical uses.
For example, if you are making a one sided PCB and need to cross over some tracks with some method, a 0R will mechanically do that without interfering much with the signal.
In the example you post, there might be electrical reasons based on what the designer was thinking. The 0R resistors can be replaced with other value resistances if necessary, or replaced with ferrite beads if needed. So the 0R can simply be a placeholder for something else and enable you to more easily test or verify or modify the circuit as needed, so you don't have to order a new board immediately if you plan ahead.
For example the VDDA resistor could be turned into a ferrite bead.
It can be impossible to say based on that narrow screeshot if there are other reasons for the resistors.
They may also useful for using them in sectioning the PCB design, and used as a link between analog and digital ground reference planes.
You may find these tricks useful in your design, or you might not. Certainly a design does not require them, you can do without.
However that circuit you show may be a poor example anyway. Usually you would not see a 47 uH inductor between VDD and VDDA supplies of the MCU. Of course a lot of the details like bypass caps are missing from the screenshot.
