From your description, I'm getting the hint you are looking to physically construct the HW with discrete components from a Verilog description so I'll address this first:
Taking on the task to build your own hardware really isn't a useful or practical task to take on. The reason is because your understanding in microcontroller hardware and architecture won't be that much greater if you can physically construct the hardware or architecture. Also, it would get so tedious in doing even trivial things. Constructing HW physically also has no functional benefit.
Above is an example of a single "NAND" gate constructed physically. I'm showing this as an example. You would need 5 components simply to accomplish the most primitive logic.
If you are interested in building HW, you should make your HW designs through FPGAs (the field programmable gate arrays you mentioned). There are plenty of development boards that hobbyists can interface with. These boards can help you get started in HW design very quickly.
An FPGA is (for sake of simplicity) an "empty" microcontroller, with no architecture or hardware. You design the hardware through some sort of design environment, and the design gets uploaded to the FPGA. This is a great hobbyist style FPGA board that I've personally used:
Mercury Nova FPGA
