I have a projector (it's a VOPLLS M10) that’s hooked up to a HomeKit enabled smart outlet, but the projector doesn’t power on when “plugged in” / smart outlet is turned on.
The projector only turns on when you hit the power button on either it, or the one on the remote. There’s no physical or digital setting on it to change this functionality.
I imagine I could buy a smart IR blaster or something (to reproduce the remote's on signal), but that’s less fun and more money considering I already have the "smart" functionality through the outlet. Is there any way I could mod the projector, or more specifically it's power button, to just turn on when plugged in? I don't have a ton of experience with this kind of stuff, just a little from back in high school, but I do have access to a solder station on my uni campus.
I've read some people on similar questions say shorting the power button's connection could work, but if you hold the power button it goes into a reboot cycle on this device, so I'm not sure thats the solution here, but maybe I'm mistaken. Here’s the uppermost board and some angles of the power button which is circled in red if that helps.
Is there any way I could mod the projector to just turn on when plugged in?
Not unless you're good at "hacking" into the embedded processor, which are typically read/write protected. \$\endgroup\$
