Yeah, I heard it before "These MOSFETs are not rated for linear use!"
There are millions of amps using oldskool FETs like IRFP240/9240 in linear mode.
More modern FETs are a different story, they will blow up if used in linear mode. But while these old FETs are not "officially" rated for linear mode, everyone uses them, everyone knows they will work absolutely fine and are extremely rugged.
But... there's of course a limit to how bad the design can be...
Let's look at the amp first.
What the hell? Where's the heat sink? It's a class AB amp, so there should be a heat sink, right? Are they... these ridiculously tiny thumb-sized things on the back of the amp?
It's a 2x50W amp so you'd expect at least 4x bigger heat sink, in a place where there's actually airflow. Compare with this random amp:
I prefer heat sinks on the sides though. They still work when the cat sits on the enclosure.
Even if the heat sinking was adequate, one pair of TO-220 devices is not enough for a 50W amp. First, TO220 has little thermal mass, so it heats up too quickly. Second, the contact area at the back is tiny, so the thermal interface between device and heat sink is always a problem.
Class AB amps have reasonably low average dissipation but peaks can be high, and power peaks tend to occur at bass frequency, which means they last long enough to heat a TO-220 to dangerous levels.
TO-247 packages offer a good amount of thermal mass, because the chip is mounted on a big chunk of copper, which helps immensely to soak up dissipation peaks. This keeps the peak junction temperature down, so while TO247 is a bit more expensive, they will get away with a smaller cheaper heatsink.
One big weak point of TO220 is the thermal interface between the device and the heat sink. The more contact area with the heat sink, the lower thermal resistance, and TO-247 wins by a wide margin simply because it's huge. These will take a lot of abuse. TO-220, not so much.
So if you use TO220 you need several in parallel. But paralleling devices with negative threshold voltage temperature coefficient is always a headache. That's why I expected to see the usual P/N pair of TO-247 IRFP240-9240 devices per channel.
Well, in this amp's case, it doesn't matter, because there's no heat sink.
A quick look at the service manual reveals a complete absence of any protection circuit of any kind: output short, overcurrent, overtemperature, etc.
Likely cause of death is exceeding max Tj repeatedly and at length. In fact the MOSFETs did pretty well if they survived that kind of abuse for that long, I'm impressed!...
So basically, it failed because the design is garbage.
