I am encountering a technical issue with a circuit I recently assembled. The circuit includes an nRF52832 microcontroller module (MDBT42Q), a 1.8V voltage regulator (LDLN025M18R) for powering a sensor, and a 3.3V step-up DC-DC converter (MAX1724) to step up the voltage from a 3V coin-cell battery (CR1220) and supply to the whole circuit. Previously, I used a 3V voltage regulator, but I observed a voltage drop to 2.7V and reduced battery life. To address this, I switched to the 3.3V DC-DC converter.
The issue I am having is that, the circuit powers up when the battery is connected but turns off after 2–3 minutes. The circuit can be restarted by removing the battery and reinserting it after some time, suggesting that the battery is not entirely drained. As I am relatively new to circuit design, I am struggling to identify the root cause of this issue.
I would appreciate any suggestions or steps to help debug and resolve this problem. I have attached the schematic.
