If you have an AC circuit and need to reduce the power going to your load, what is the difference between commonly-known ways of achieving that?
Because most of my electrical experience is related to houses in the USA, I'm thinking of like 120V, 20A circuits with a breaker run through copper wire, where some household appliance is the load.
I am asking because in my beginner-level study of electronics, I have already heard multiple times how using a resistor would be "inefficient" or "no power savings", but without further explanation. I have also heard about how a longer wire would increase resistance too, but never heard of it as being "inefficient" for some reason. Note that much of this is what I've learned from electricians or the internet, not academically.
My understanding is that using a resistor or longer wire to reduce the power would be roughly equivalent in terms of efficiency, as some of the reduction in power will be lost as heat in either method. So, if I had a circuit where the load used 100W and then added in a resistor or made the wire longer such that the load used 50W, the entire circuit would be using a bit more than 50W because of the resistor or longer wire. But my guess is that in practice using a resistor to lower the power (eg, a dimmer lightbulb or ceiling fan) is still a power savings over not having the resistor.
Another guess based on experience is that one of the more efficient ways of reducing power is to just use a transformer to lower the voltage and have your appliance designed to operate at that voltage.
So, I do not why any of these methods of reducing power is significantly different from the other, and why I have heard so much about how a resistor specifically is "inefficient" or would result in the same power being consumed by the circuit as a whole.
