I'm getting a PCB made with an OpAmp circuit on it that will need some tuning. We aren't sure what resistance and capacitance values we'll need to use for the integrator circuit. These will need to be calculated, tried, tested and tuned after the PCB is made.
I know we will be changing those components out frequently until we get the response that we want.
Is there an easy and robust way to swap out these components as we iterate?
It is a wearable so for testing purposes the solution should be rigid and compact-ish. Right now I am thinking through hole components and just de-solder and solder different values. I was thinking of variable resistor but the values for this circuit could vary from 10kOhm - 10MOhm.
The frequencies carried by the resistors will be in the range of 500 – 1000 Hz.
