I want to sense 3D motion (gesture). I have 3 axis accelerometer. But I am confused if I need a gyroscope or not for orientation and rotation sensing.
  1. Isn't it possible to measure them from accelerometer alone? Because when the sensor rotates along one axis (say z-axis), there will be change in y-axis and x-axis output in accelerometer.
  2. Is gyroscope really necessary or is it just easier if I have one?
Consider an accelerometer experiencing a net acceleration of gx - gz.
There are an infinite possible ways to achieve this, here are few examples:
  1. The sensor is oriented with z pointing towards the sky, and the user is moving it laterally relative to the ground with acceleration g.
  2. The sensor is oriented x pointing towards the ground, and the user is moving it laterally relative to the ground with acceleration -g.
  3. The sensor x/z plane is oriented at a 45 degree angle, and the user is moving it in a down-ward/left direction.
  4. The sensor is rotating about some point, moving with a non-constant velocity such that the acceleration is gx - gz.
etc.
So a single accelerometer cannot determine its orientation if it's experiencing acceleration and gravity.
