Regarding the microcontroller.
ALU - The Arithmetic Logic Unit performs all calculations involving registers and/or logic for decision making. It is connected to and controlled by the CPU in a microcontroller.
Also, the ALU is the component responsible for performing mathematical operations (addition, subtraction, etc.) and logical operations (AND, OR, NOT, etc.). In a microcontroller, the ALU is essential for data processing and instruction execution.
CU (Control Unit) Control Signals (black arrow pointing to the ALU): o The Control Unit (CU) generates control signals that determine the operation that the ALU should perform. o These signals control, for example, whether the ALU should add, subtract or perform a logical operation. o The CU decides which operations the ALU should perform based on the instructions of the program being executed.
1- I didn't understand the explanation of the CU (Control Unit). How do signals control, for example, whether the ALU should add, subtract or perform a logical operation? This doesn't make sense to me. 2- In this case, control signals determine the operation that the ALU should perform. But wouldn't the ALU itself do this?
