I am planning to fix my broken headphones. They don´t really work in my laptop unless I twist the plug-in wire to a certain position and hold them there. I think it´s just a broken wire somewhere close to the plug-in? I was thinking of cutting the wire close to the plug-in and solder the wires to a new plug-in. Do you think my assumptions are correct? What are the best tools to use for this task?
    \$\begingroup\$ The picture you post and the item you like to, are not the same. The Sennheiser Adidas CX 680i you link to has an inline remote, and has a 4 conductor TRRS plug. Using a 3 conductor TRS plug will mean some feature gets disabled. Additionally, TRRS replacement plugs are not easy to find, especially right angle. \$\endgroup\$ – Passerby Jun 18 '13 at 3:41
  • \$\begingroup\$ Repair questions are off-topic. \$\endgroup\$ – Leon Heller Jun 18 '13 at 7:47
  • 6
    \$\begingroup\$ We shouldn't turn away questions just because they are about repair. meta.electronics.stackexchange.com/questions/684/… \$\endgroup\$ – travisbartley Jun 18 '13 at 8:27
6
Its unfortunate that these headphone jacks are all too often designed to fail. If you take the time, you can learn to repair them and even make them stronger than before.
Materials You will need wire strippers/cutters, a replacement jack with wire slots, electrical tape, a soldering iron and some solder. The replacement connector should be able to unscrew, revealing the wire slots and solder points. They can be purchased very cheap and are much better to use than an old connector that is not made for replacing.
Preparation Cut the cable near to the faulty jack. Strip the outer sheath about 1/2". There will likely be three colored wires covered in enamel. First, separate the colors and then you will need to remove the enamel. This can be done using a bead of hot solder which will melt the enamel and tin the wire. Or if you have acetone/nail polish remover and mineral spirits those work well too. If none of those works for you, you will have to carefully scrape off the enamel with steel wool or a knife. This is the most tricky part, but if you don't remove the enamel, the headphones won't work perfectly.
Soldering Next you have to match each color with the tip, ring or sleeve of the headphone jack. For this type of connector, the tip is left channel, ring is right channel and sleeve is common. Generally the red wire is right channel, the blue wire is left channel, and the bare copper one is common. If the stereo orientation is wrong, reverse the red and blue connections.
Reinforcement After testing the audio and L/R orientation, you may need to reinforce the wire with electrical tape and epoxy. Epoxy can be put over the solder joints so that when the cable is pulled, the tension is put on the epoxy instead of on the soldering joints which could make them weaken and break over time. With electrical tape, the idea is to put it thicker near the connector and taper it off. This way, if you pull the wire sideways, the wire will bend like a fishing rod, distributing the load over a few inches instead of just one point.
    \$\begingroup\$ Good info, in my experience though, right is red, left is white, even inside headphone cables. \$\endgroup\$ – Passerby Jun 18 '13 at 3:39
    \$\begingroup\$ Maybe the convention is different between companies or regions. I've even seen green wires. The important thing is to test them after soldering. \$\endgroup\$ – travisbartley Jun 18 '13 at 3:55
  • \$\begingroup\$ Yea, simply cut the plug a bit long, so you can stick a continuity meter on the plug and the wires, to confirm. \$\endgroup\$ – Passerby Jun 18 '13 at 4:56
  • \$\begingroup\$ "I remember this with the mnemonic Red Right bLue Left Copper Common" electronics.stackexchange.com/questions/6698/… \$\endgroup\$ – travisbartley Jun 20 '13 at 2:50
  • \$\begingroup\$ are there specific headphone jacks I should purchase for the repair? Will all headphone jacks not be compatible? \$\endgroup\$ – l3win Jun 27 '13 at 21:12
protected by W5VO Jun 18 '13 at 13:38
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
