Say I want to have the 90Ω differential impedance on the USB data lines, on a triple-stacked type A USB connector, where D3 and D2 ports share the same USB data lines: usb impedance question
Would it make more sense to connect them like this, to lessen the reflection due to the impedance mismatch from the transmission line changing in width:
usb impedance connection 1
Or the signal integrity would be better if I try to keep the 90 Ohms impedance with the tracks: (But there will be more reflections due to the impedance mismatch here):
usb impedance connection 2
The best approach would be to use EM simulators on the design and then a TDR (time domain reflectometer) on the physical PCB, but I have none of these tools. Until now, I always go with the first approach, aka if I can not keep the impedance the same all through the transmission line, I would "submit" to the change and I would keep the "new impedance" as long as needed (even if the tracks were longer in this example), so that I have as few changes on impedance as possible.
Same question for a single transmission line, assuming I want to keep the impedance the same and I need to make the track thinner at one point. After that point, Is it better for signal integrity to increase the width of the track again (bottom picture) or keep the thinner track (top picture)?
Same impedance question with one track
Again, in this case I always pick to keep the thinner track, as I assume there will be less reflections overall.
  1. What is the approach for example on a same problem, but with faster signals, like DDR memories on motherboards design?
  2. Maybe this is a question with answers based on each individual cases and can only be answered using simulations and TDR to measure the impedance changes?
  • \$\begingroup\$ Are you aiming for this to carry high-speed signals, or just full-speed? || It is very unusual for two physical connectors to share the same data lines. Are you certain this is what you need? \$\endgroup\$
    – Hearth
    Commented Nov 26 at 14:16
  • \$\begingroup\$ @Hearth We solder either double-stacked connector there, where you have 2 different data lines. Or we solder triple-stacked connector, where youd use the bottom and top connectors only. So the second connector just wont be used, signals wont be mixed. \$\endgroup\$ Commented Nov 26 at 15:42
The type-A plug-socket pair introduces a fairly big discontinuity. Whatever you're doing with those little traces won't matter much. Sure you'll get quantitative answers with a TDR - but they are not really needed. As long as the eye diagram is open enough per the spec, you won't have to worry.
I would look for a test signal generator and a fast oscilloscope with a fast differential probe first, since that lets you see the eye and correlate that with the USB spec to see if you're within the limits. No need for a TDR. The eye is the figure of merit here. You can use USB host, say a Raspberry Pi, as the signal source. It's cheap and if you damage it, it won't hurt the pocket as much.
