I bought four 5 kg load cells (link) and connected them all together (all white cables, all green cables, etc.). Then I hooked them up to the HX711:
wiring
When I read the values from the Arduino using the HX711 library, I can read the numbers and I can tara the scale. Here the very simple code (tara is done in the client):
#include "HX711.h"
HX711 scale;
const int LOADCELL_DOUT_PIN = 4;
const int LOADCELL_SCK_PIN = 5;
void setup() {
  pinMode(LOADCELL_DOUT_PIN, INPUT);
  Serial.begin(9600);
  while (!Serial) {
  scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
void loop() {
  if (scale.is_ready()) {
    long reading = scale.read_average(10);
    Serial.print(": ");
    Serial.println(reading);
  } else {
    Serial.println("! not ready");
  delay(300);
This works really well and I get realistic, precise measurements. However, the problem is, that the readings drift quite a bit over time. The readings vary 10 to 100 gram in a few seconds. Also it seems to be directional. Often it goes down, down, down, down. And only a few times up. Here a chart of the absolute values (a few minutes, drift of up to 12%):
measurements
I tried using different Arduinos (Uno & Nano). I tried to use four HX711 and yesterday I soldered all cables of the load cells together (but I am still using a bread board and jumper cables for the rest).
I really have no ideas what to try next. Please help.
  • \$\begingroup\$ HX711 is "ratiometric". Try a capacitor (100 nF) directly on pins E+ and E- of the board. E+ and E- are "outputs", I think. So can't be wired to Uno power supply. Decouple also, if needed, VCC and GND on the board. C6 should do it, but perhaps not enough (long wiring). \$\endgroup\$
    – Antonio51
    Commented Nov 29 at 9:26
  • \$\begingroup\$ hey @Antonio51, wow there are a lot of ideas. Thanks! Since I am not a professional, can you "unpack" the things a little for me? - I can add a capacitor. Can you share why this is might solve the problem? - Mmm, so I should not use the power source of the Arduino? Would a powerbank do? (since batteries tend to be more stable?) - What do you mean with "also"? Decouple the Uno and something else too? - What does C6 refer to (googling did not yield results)? \$\endgroup\$
    – Motine
    Commented Nov 29 at 11:40
  • \$\begingroup\$ C6 is the capacitor on the board HX711.. 1uF-10 uF should be ok. Since you are using "long"wires, decoupling more should be ok. Try also torsading this long wires by pair. \$\endgroup\$
    – Antonio51
    Commented Nov 29 at 13:31
You've apparently got some reading issues as evidenced by those spikes. Maybe give Sparkfun's library a try.
The downward trend is a bit like load cell creep, but the amount seems large (though perhaps not for a $4 load cell- 10 grams is only 0.2% of full scale) perhaps try replacing the load cells with similar valued precision resistors to determine the source of the drift.
  • \$\begingroup\$ Thanks for the ideas. Just a quick question: Do you see another library than I? When I follow the link on the Sparkfun page, I land on the same library as I shared. \$\endgroup\$
    – Motine
    Commented Nov 29 at 12:22
  • \$\begingroup\$ Yours is github.com/bogde/HX711 and the link I gave is to github.com/sparkfun/HX711-Load-Cell-Amplifier , I don't know if the content is the same, but they are two different github repositories. \$\endgroup\$ Commented Nov 29 at 15:43
    \$\begingroup\$ SparkFun uses the same bodge/HX711 library. \$\endgroup\$
    – hcheung
    Commented Nov 29 at 23:46
  • \$\begingroup\$ Okay, kind of looks like a timing issue - maybe the not ready line is being reached. \$\endgroup\$ Commented Nov 30 at 1:34
  • \$\begingroup\$ found it via google: github.com/adafruit/Adafruit_HX711 unfortunately, the library was not the culprit. \$\endgroup\$
    – Motine
    Commented Dec 2 at 9:52
