I'm struggling to understand the chart of device current versus area of copper for heat dissipation in the datasheet for an LT4423 ideal diode and load switch. My output current will be around 1A at 12V.
How does one read this chart?
Choose one of the ambient temperatures - that's the upper limit you design for. From now on, only consider the plot marked with that temperature and ignore others.
Choose your diode current. Draw a vertical line at that current.
If the line does not cross the curve of your choosing, the operating current is too high to accommodate with \$<2{\rm\ in}^2\$ of copper.
Where the line intersects the curve, draw a horizontal line.
Read out the needed thermal copper area from the vertical position of the horizontal line.
