I was given the following question:
Given the following truth table, implement the 2 functions needed for \$cout\$ and sum (\$s\$) using only XNOR, NAND and OR (only the 2 inputs version for each gate) such that the total number of gates used is at most 10 (in both function combined). Here's the truth table:
What I tried so far was first to make a K-map for each one of the functions to get simplified expressions in terms of OR and AND gates, I got the following expressions (for means of simplification, I wrote \$cin\$ as \$c\$, and \$a\_ns\$ as \$s\$ and the output for the second function (\$s\$) is just called \$sum\$): $$ cout = bc+abs+acs+a'bs'+a'cs' $$ $$ sum = a'bc'+a'b'c+abc+ab'c' $$
also tried to write \$cout\$ as : $$ as(b+c)+a's'(b+c)+bc=(b+c)(XNOR(a,s))+bc. $$
I know how to express it with only the given gates but with way more than 10.
Any help would be much appreciated!
Here's a clue to get you started: -
That uses two XNOR gates to make s.
