I’m analyzing the attached graph (which I wrote in Matlab), which shows the capacitance of an MOS capacitor as a function of the surface potential: $$\psi_s$$ for different temperatures. The graph displays distinct differences between the curves at various temperatures, and I want to confirm if these trends are consistent with theoretical expectations.
Questions:
  1. Does the shape and behavior of the capacitance vs. surface potential curves align with physical results for an MOS capacitor under varying temperatures?
  2. If the graph is correct, could someone explain the observed differences in capacitance as temperature changes (e.g., in terms of depletion width, carrier distribution, or other factors)?
System Parameters:
Here are the key parameters used for the analysis:
-Charge of an electron: $$q = 1.6 \times 10^{-19} \, \text{C}$$
-Boltzmann constant: $$k_B = 1.38 \times 10^{-23} \, \text{J/K}$$
-Vacuum permittivity: $$\varepsilon_0 = 8.85 \times 10^{-14} \, \text{F/cm}$$
-Relative permittivity of silicon: $$\varepsilon_{\text{Si}} = 11.8$$
-Relative permittivity of silicon dioxide: $$\varepsilon_{\text{ox}} = 3.9$$
-Doping concentration: $$N_A = 10^{15} \, \text{cm}^{-3}$$ -Oxide thickness: $$t_{\text{ox}} = 20*10^{-6} \, \text{cm}$$
New contributor
לירן גלמידי is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
20 micrometers is far larger than ever used in practice.
Na is typical. For a very large oxide thickness I expect the minimum capacitance to be not much smaller than Cox. I think something is wrong.
Also: phis(inv) is larger at low temperatures not smaller.
New contributor
Fred is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
  • \$\begingroup\$ yeah Im sorry, I typed here 20 um instead of 20e-6 cm , I editted this now, can you explain why phis(inv) is larger at low temperatures not smaller? \$\endgroup\$ Commented 11 hours ago
