I wrote a Testbench for a simple architecture. When I use the literal "1 ms" instead of the constant ct: time := 1 ms everything works. But otherwise GHDL stucks in an infinite loop.
Can you see an error in the code or is this a bug of GHDL?
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity s is
port
    a: in std_logic;
    b: out std_logic
end s;
architecture v1 of s is
begin
b <= not a;
end v1;
library ieee;
entity testbench IS
END testbench;
architecture v1 of testbench is
component s
    port
        a: in std_logic;
        b: out std_logic;
end component;
signal a: std_logic := '0';
signal b: std_logic := '0';
constant ct: time := 1 ms;
begin
    a <= not a after ct; --constants not working?
    -- but no problem with a <= not a after 1 ms;
dut: s
    port map
        a => a,
        b => b,
end architecture;
  • \$\begingroup\$ Is this the exact same code you use for simulation? First thing I would delete that superfluous comma in the port map of the DUT after b => b. Besides that, everything looks like correct VHDL syntax. \$\endgroup\$ – damage Jun 21 '13 at 1:37
Which version of GHDL? I have just tried the example (fixing two typos mentioned by "damage"), and both forms appear to do the same thing.
By the way, +1 for a nice simple testcase.
I am using the following:
uname -a
Linux Gannet 3.2.0-4-amd64 #1 SMP Debian 3.2.39-2 x86_64 GNU/Linux
 ghdl --version
GHDL 0.30dev (20100112) [Sokcho edition]
 Compiled with GNAT Version: 4.7.2
 gtkwave --version
GTKWave Analyzer v3.3.46 (w)1999-2012 BSI
and the commands:
ghdl -a s.vhd
ghdl -a v1.vhd
ghdl -e testbench
./testbench --vcd=test --stop-time=50ms
gtkwave test
The result looks like this: enter image description here
Now this version of GHDL is currently only available as an experimental package for Debian (Ubuntu etc) - for other distributions and OSes it is only available by building from source : see "instructions" section in message 4 at this GHDL bugreport page for details. However it is my belief that GHDL 0.29 should also work in your case; earlier versions may not.
UPDATE: this has also been the first test of GHDL built with gcc4.8 ... looks OK so far!
