I was following this microphone and speaker circuit and I could follow mostly but got confused when the author introduces a DAC buffer.
http://www.instructables.com/id/Arduino-Audio-Output/?ALLSTEPS
This isn't the first place I have seen engineers putting a buffer stage in amplifier designs. I want to improve my understanding of how these unity gain buffers are useful in circuits. i.e what goal do they achieve? How important is it to put buffer stages in amplifier circuits and exactly when should we take introducing buffer stage into consideration? Appreciate it!
A buffer can serve many purposes in a circuit. There are other uses besides what I mention below, but these are some fairly common ones you might encounter.
One common use is as a time delay in data transmission. It can take a bit of time for a chip to recognize the change in a signal's voltage level and react to it (such as a digital HI to LO transmission). The amount of this slight propagation delay varies from one device to the next. Sometimes it is a few nano seconds, sometimes it is much more. Also, it does take some time for the signal to propagate through the copper from one part of the circuit board to another. When there are one or multiple data signals moving from one part of the circuit to another, it may be necessary to delay one so that they arrive in a specific order or at exactly the same time.
Buffers can be used as momentary data storage. Similar to the time delay, there are situations when you need a small amount of time to store a data bit such as pipelining, but this example can be a bit difficult to explain, depending upon your knowledge of computer architecture.
Another example is signal isolation. Because a buffer is essentially a signal repeater, it can be used to isolate the signal from two parts of the circuit. This is the specific use in your example, as noted by Ignacio in his answer. In this particular case, the DAC (digital to analog converter) is sensitive to loads. A load can be anything from a resistor, speaker, IC input, or even just a piece of wire. This "sensitivity to load" means the signal may change (distort) if too much or too little of a load is seen at the output of the DAC. To prevent this, a buffer chip is used to repeat the signal from the DAC output. The output of the buffer can be connected to whatever you want (within its own limitations) without affecting or distorting the output from the DAC in any way.
Lastly, a buffer can be used a signal amplifier. This is very similar to the previous example, but the reasons for using it can be different. While the output of some chip might not be extremely sensitive to loads, it may only be able to supply a few milliamps of current. In this case, you may want to use a buffer with a larger output current rating to amplifier the original signal so it can be used to drive some larger load.
From the article:
The R2R DAC is very sensitive to any loads put on it, so trying to drive speakers directly from the DAC will distort the signal heavily.
So in this case the buffer is used to isolate the DAC from the load.
  • \$\begingroup\$ Sorry but that explanation is still vague for me. What does isolate mean in that context and why do we do that? How does buffer solve it? \$\endgroup\$
    – user734861
    Jun 22, 2013 at 0:06
  • \$\begingroup\$ Sense 4. The buffer reads the voltage being generated and reproduces it on its output while not allowing the load to affect the input. \$\endgroup\$ Jun 22, 2013 at 0:08
