-2
I started learning verilog recently and I tried this simple code:
module hello_world ;
initial begin
$display ("Hello World by jai");
#10 $finish;
end
endmodule
Then, I set this module as Top_Level Entity, and clicked Analysis and Synthesis. Then comes the error:
Error: Can't synthesize current design -- Top partition does not contain any logic.
How can I use these tasks in Quartus, or can they be only used in software where we can write testbench (like Xilinx ise)?
I'm using Quartus II 9.1sp2.
  • \$\begingroup\$ Do you know that this code can not be synthesized, so so what ate you trying to do with this? \$\endgroup\$ – FarhadA Jun 23 '13 at 21:38
  • \$\begingroup\$ While these statements are not synthesizable, major FPGA vendors do offer a scheme which you can compile in to monitor values of the running design via the programmer cable, as a sort of built-in logic analyzer. \$\endgroup\$ – Chris Stratton Jun 28 '13 at 15:39
You are looking for a verilog simulator, rather than synthesis tool to execute code like this.
