I am trying to build a T flip-flop from a D flip-flop. The D flip-flop looks like this enter image description here
and the simulated waveform shows that it works.(when there is a rising edge D will be passed to Q) enter image description here
So I started building a T flip-flop by connecting Qnot to D (I am expecting every clock rising edge Q will be toggled because Qnot is passed to Q) enter image description here
but the simulated waveform looks like this enter image description here
Q will oscillate when CLK is low. One oscillation period is around couple ns. I played with different Clear and Preset signals but it still happens.
If anyone can point out my errors. Thanks.
    \$\begingroup\$ The first thing is not a FF, it's a latch. \$\endgroup\$
    – avakar
    Commented Jun 24, 2013 at 20:06
The first schematic shows a latch rather than a D flip-flop -- it forwards D to Q when CLK is high. Q maintains its value for CLK low.
This would almost explain the behavior of your latter circuit. Q should remain constant when CLK is low. It will forward !Q when CLK is high and therefore oscillate.
Why the oscillation happens with CLK low I cannot explain (perhaps the two screenshots are inconsistent?).
  • \$\begingroup\$ The first circuit is indeed a latch. Sorry I was confused. But I took the screen shots after I compiled two circuits with no errors. Still struggling with the oscillation. \$\endgroup\$ Commented Jun 24, 2013 at 21:08
  • \$\begingroup\$ So would Q oscillate when CLK is high because !Q is passed to Q continuously as long as CLK is high? It looks like I cannot build a T flip-flop from it then... \$\endgroup\$ Commented Jun 24, 2013 at 21:12
When the clock is HIGH there seems to be a race hazard through the circuit which causes a rapid oscillation.
Lets assume the starting condition is Q = 0 (NOT Q = 1)
when the clock signal goes HIGH
                        a b c d e f g
                        1   1 0
g will go low causing d to go high causing c to go low causing g to go high and so on and so forth
when clock is low
                        a b c d e f g
                        0   1 0
f is low, b is high, c is high the system is stable
  • \$\begingroup\$ Thanks for walking it through. Your analysis is right. My implementation to build a T flip-flop is incorrect because the toggle happens too much when CLK is high. \$\endgroup\$ Commented Jun 24, 2013 at 21:21
  • \$\begingroup\$ Timtianyang - your very welcome, good luck with you next implementation \$\endgroup\$ Commented Jun 25, 2013 at 7:27
