In a lab for an "Introduction to Electric Circuits" course, I built a simple Half-Adder circuit using an 74LS08 IC & 74LS86 IC. However, I'm experiencing issues with the output.
My input voltage
supplied to Pin 14 on the 74LS86 IC was +5V and I verified that the output voltage
(Pin 3 on the 74LS86) was +3.4V. The results from this IC were what I had expected; however, the output of the AND gate
(Pin 3 on the 74LS08) was LOW when the two inputs were HIGH and was HIGH when the inputs were LOW. Below is the Truth Table
for the 74LSO8 IC.
A B Y
0 0 1
0 1 0
1 0 0
1 1 0
And here is the Circuit Diagram
What would cause this behavior? As I understand, when the inputs are LOW the output should be LOW and when the inputs are HIGH the output should be HIGH.
