I do have an Arduino Nano (v3.0) board and to my surprise the USB (and communication with board) is disabled after I restart the PC.
If I do unplug and plug the USB cable the USB port becomes available.
Is this an Arduino Nano "feature"? (As I see that my other Arduino UNO board works fine after a reboot)
  • \$\begingroup\$ This is a user-level question having nothing to do with electrical engineering. \$\endgroup\$ Jun 26, 2013 at 14:53
    \$\begingroup\$ @olin-lathrop That is why I asked if it's something specific to Nano architecture \$\endgroup\$ Jun 26, 2013 at 16:05
  • \$\begingroup\$ Maybe you can delay the reset line on the Arduino with a capacitor long enough for the PC to have initialized the USB bus? For starters you could try to manually pull the reset line low and see if the device registers with the PC as you expect. \$\endgroup\$
    – jippie
    Jun 26, 2013 at 17:53
  • \$\begingroup\$ I'd be tempted to ask if you could tell us about how it behaves in the case of power-on while connected vs a warm restart while connected, but I don't know if what passes for bios these days would initialize the USB bus before the ultimate operating system re-initializes it, and that might destroy any difference. \$\endgroup\$ Jun 26, 2013 at 20:24
  • \$\begingroup\$ @jippie I connected the reset to the ground of board and indeed the board reset and then appeared in the Device Manager. The 3rd time I tried that I think I did something wrong as I burned the board :D I will get a some extra boards and I hope I will not do the same mistake. \$\endgroup\$ Jun 27, 2013 at 7:04
Pin 19 (RESET) of the FT232RL (USB driver) seems to be unconnected according to Nano's circuit diagram.
Double check if this is indeed the case. If so, try connecting a 100nF capacitor from that pin to ground and a 10k resistor to +5V. This may reset the device long enough for the USB host (PC) to initialize.
  • \$\begingroup\$ Can you check this diagram and let me know if that is what you meant? \$\endgroup\$ Jun 27, 2013 at 7:05
  • \$\begingroup\$ This link FTDI USB locks up on power up seems very similar to my problem. Could it be the same? \$\endgroup\$ Jun 27, 2013 at 17:30
  • \$\begingroup\$ Not sure if it is the same issue, it seems similar indeed. I updated my answer with a circuit diagram, does that clarify thing? \$\endgroup\$
    – jippie
    Jun 27, 2013 at 19:12
  • \$\begingroup\$ Does the down arrow (with empty triangle) has to be connected to another GROUND (from Arduino board for example) or is just a convention? \$\endgroup\$ Jun 29, 2013 at 9:16
  • \$\begingroup\$ It is common ground on the Arduino. \$\endgroup\$
    – jippie
    Jun 29, 2013 at 11:00
