Question 1: When one interrupt handler is executed, will it be interrupted if another interrupt with the same priority occurs?
Question 2: When one interrupt handler is executed, will it be interrupted if another interrupt with the lower priority occurs?
I used MSP430. The interrupts are always nested as long as GIE is enabled. The priority is only determine whose interrupt handler is executed first if there are a few interrupts occurred at the same time and pended (before they are responded). But I don't find any answer for Cortex-M0 in its documents and google search.
  • \$\begingroup\$ Get DUI0497 Cortex-M0 Devices Generic User Guide. \$\endgroup\$
    – starblue
    Jun 28, 2013 at 7:52
  • \$\begingroup\$ Thanks, starblue. Just see your comment. You're right. This doc explains to all my questions very clearly. \$\endgroup\$
    – hailang
    Aug 8, 2013 at 22:44
The part that handles these things in a Cortex is the Nested Vectored Interrupt Controller (NVIC).
No, an interrupt will be acknowledged if it has a higher priority
No, not while the interrupt handler is running.
  • \$\begingroup\$ Thanks for your answer, Wouter. infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0337e/… Pre-emption: New exception has higher priority than current exception priority or thread and interrupts current flow. This is the response to a pended interrupt, causing entry to an ISR if the pended interrupt is higher priority than the active ISR or thread. When one ISR pre-empts another, the interrupts are nested. \$\endgroup\$
    – hailang
    Jun 28, 2013 at 13:21
  • \$\begingroup\$ Thanks for your answer, Wouter. In the link below, it is mentioned: infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0337e/… Pre-emption: New exception has higher priority than current exception priority or thread and interrupts current flow. This is the response to a pended interrupt, causing entry to an ISR if the pended interrupt is higher priority than the active ISR or thread. When one ISR pre-empts another, the interrupts are nested. \$\endgroup\$
    – hailang
    Jun 28, 2013 at 13:32
    \$\begingroup\$ Does this mean that the new exception always has higher prioirty than current one, so the currnt one will be pre-empted no matter theirs designated priorities? \$\endgroup\$
    – hailang
    Jun 28, 2013 at 13:35
  • \$\begingroup\$ Supplement: “2.3.5 Exception priorities” in <DUI0497A_cortex_m0_r0p0_generic_ug.pdf> has good information. \$\endgroup\$
    – hailang
    Aug 8, 2013 at 22:41
  • \$\begingroup\$ Test results: Same interrupt can’t preempt the running one. \$\endgroup\$
    – hailang
