How does avrdude with AVR-ISP-MK2 respond when no target board is connected?
I'm trying to troubleshoot my set-up, and would like to know if the problem lies between the laptop and programmer or between the programmer and target board.
For me, this avrdude command gives the same result regardless of whether the target board is connected or not. It doesn't matter if the file exists or not.
# avrdude -c avrispmkII -p m328 -U flash:w:flashled.hex
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200012345
avrdude: Sent: . [01]
avrdude: usbdev_recv_frame(): usb_bulk_read(): Input/output error
avrdude: stk500v2_recv_mk2: error in USB receive
  • \$\begingroup\$ What OS are you on? \$\endgroup\$
    – user151324
    Jun 27, 2013 at 16:10
  • \$\begingroup\$ What commands are you running? \$\endgroup\$
    – user151324
    Jun 27, 2013 at 16:11
  • \$\begingroup\$ @coding_corgi I'm on Arch Linux x86_64 and have tried avrdude -c avrispmkII -p m328 -U flash:w:filename.hex. I've already updated the AVR-ISP-mk2 firmware using Atmel Flip to the one that handles avrdude and libusb. \$\endgroup\$
    – Andreas
    Jun 27, 2013 at 16:12
  • \$\begingroup\$ Ok, well, i had trouble with my AVR ISP MKII on Ubuntu (until it blew up) and i was getting similar errors, are you compiling .c/.cpp files? \$\endgroup\$
    – user151324
    Jun 27, 2013 at 17:02
  • \$\begingroup\$ @coding_corgi Yes, I'm compiling .c files using avr-gcc. But that doesn't matter: I get the same behaviour regardless of whether the .hex file exists or whether the target board is connected to the programmer. \$\endgroup\$
    – Andreas
    Jun 27, 2013 at 17:37
Update: README.xcompile.20180518 is in the same repository, but has been revised for the latest stable gcc (8.1.0), binutils (2.30), as well as some other refinements. The avrdude-6.3 patch remains alarmingly relevant. Hope this helps...
Update: I've retained a github repository with full instructions for building the cutting-edge AVR GNU toolchain (including avr-gcc 7.2.0 and avr-libc 2.0.0), as well as patching avrdude-6.3 to eliminate USB I/O errors.
The instructions are focused on OS X (using MacPorts), but should be easy to adapt for Unix / BSD hosts.
It also provides instructions for using dfu-programmer to flash the Olimex AVR-ISP-MK2 for libusb-based firmware, overwriting the factory default AVR Studio firmware.
Since then, I've had no issues. I cobbled together a minimal programmer board with a 40 PDIP ZIF socket that draws 5V power from the AVR-ISP-MK2 with 5V:ON jumper setting.
good enough for quick programming!
Simple veroboard implementation for quick and dirty programming...
Older Instructions:
I know this is a late answer - but the Olimex AVR-ISP-MKII needs a firmware upgrade for use with avrdude (as opposed to AVR studio - see documentation).
Since I'm on OSX, the Atmel Flip utility wasn't a convenient option. Instead, I grabbed dfu-programmer, and flashed the programmer with the firmware libUSB-AVRISP-MKII.hex available from Olimex:
  1. Connect the programmer, and press the upgrade pin - the LEDs should turn off.
dfu-programmer at90usb162 erase
dfu-programmer at90usb162 flash libUSB-AVRISP-MKII.hex
dfu-programmer at90usb162 start
At this point, the orange and red LEDs were on.
You may have to tweak the dfu-programmer source, if libusb-1.0 (required) lives somewhere besides /usr/include. I'm considered submitting an improved configure.ac and build system. (MacPorts users can install the dfu-programmer and dfu-utils packages.)
Plugging the ICSP10 into my cheap AVR-P40-8535 board, with an ATmega8535 in the socket (the MKII jumpers set to ON:5V) :
running: avrdude -c avrisp2 -p m8535 -P usb
returned the correct device signature "0x1e9308" for the ATmega8535.
  • \$\begingroup\$ Thanks for your answer. I did manage to update the firmware using Atmel Flip, but that didn't change the results. I got it working on a Windows machine, so I haven't spent any more time trying to fix the Linux set-up. \$\endgroup\$
    – Andreas
    Aug 20, 2013 at 5:09
