I had read about Thevenin's theorem that:
If the resistors in part A are in parallel-series configuration, the Thevenin resistance can be obtained readily by combining resistances. If, however, part A contains dependent sources (remember, they are not deactivated), then, of course, resistance combination is not applicable.
  1. Why is in the mentioned case "resistance combination is not applicable"?
  2. Why are dependent sources never deactivated in application of this theorem?
  • \$\begingroup\$ This is the second time I'm going to our editing help. It would be really helpful if you'd use Markdown instead of HTML. Also, please remember that we don't say 'thank you' at StackExchange - we upvote. \$\endgroup\$
    – user17592
    Jun 28 '13 at 16:09
  • \$\begingroup\$ At last, when you refer to something, please put a link in your question if you're referring to a website. \$\endgroup\$
    – user17592
    Jun 28 '13 at 16:10
  • \$\begingroup\$ @user, no need to accept an answer right away. Of course I appreciate that you found my answer solved your problem, but if you wait 24 hours, you give people in every time zone a chance to answer, and somebody might come up with a clearer or more complete explanation. \$\endgroup\$
    – The Photon
    Jun 28 '13 at 17:04
When solving a network with multiple independent sources, we can use the superposition principle. This means deactivating all except one independent source one by one and solving the network for each case, then combining the results to get the solution for the network with all sources active. This is probably what your text is talking about when it talks about "deactivating" some sources.
You can't deactivate controlled sources when doing this process because a controlled source in a network with no independent sources wouldn't produce any output, so it can't be analyzed independently. The behavior of the controlled source has to be analyzed as it responds to each of the independent sources in turn.
In a network with controlled sources, you can't simply combine resistors like you do in a purely resistive network. Because there's more than just resistors in the network.
There are in fact special cases where a controlled source is hooked up to behave like a resistor, but in the general case, you have to treat them differently.
