Here is a picture of board:
I want to route pad 23 to 48. But the path gap is narrow. So I am not able to route it. Auto routing also couldn't route. I changed the design rules for solder mask and track width as much as possible.
How can I achieve the routing?
  • \$\begingroup\$ Can you give more information on the package you are using, and/or the grid scale? \$\endgroup\$
    – W5VO
    Jun 28, 2013 at 16:23
  • \$\begingroup\$ @Camil Staps I am using 0.025mm grid \$\endgroup\$
    – zud
    Jun 28, 2013 at 16:33
    \$\begingroup\$ A link to the part you are dealing with would help. \$\endgroup\$
    – The Photon
    Jun 28, 2013 at 17:08
There is no magic bullet here. You either use smaller trace/space widths, route it a different way, or you don't route it at all.
    \$\begingroup\$ Using a smaller annular ring on the inner layers than the outer layer could help give more clearance. \$\endgroup\$
    – The Photon
    Jun 28, 2013 at 18:40
Can you place a Via close to the Pad and then go on a lower layer? You might also want to look at typical fanouts: http://wiki.altium.com/display/ADOH/Fanout+and+Escape+Routes
Addition: You might want to plug that via to prevent tin from being sucked into the hole
