I need a help from someone who knows DALI standard well and has experience on it and knows DALI control gears' structure.
I make a DALI related application and aim to detect if the connected lamp is broken. To do so, I send following commands to the DALI control gear (slave)
0x92 Check if there is a lamp failure
0x93 Check if the lamp is operating
0x9B Check if the slave is in power failure mode
before it, I disconnect the lamp unit, then send the commands above, however, the slave unit does not report any failure. I use couple different DALI unit of Tridonic. I wonder why removing a lamp source do not generate a failure report?
Could you please explain the logic how the DALI control gears detect the broken lamps (e.g. in what cases the DALI unit generates response to 0x92
, 0x93
, 0x9B
What command is the best to detect the broken lamps?
EDIT: I send 144 query message, its definition on the standard:
As a reply, I get this signal at the oscilloscope:
means:
start bit(1) | reply (8) | stop bits(2)
1 | 0 0 0 1 0 1 0 0 | 1 1
means:
- 0: the ballast is working fine
- 0: no lamp failure is detected (if there is no lamp unit, why it is not a failure? and what is the description of the failure?)
- 0: arc power is off?
- 1: limit error -- (I send 0xFEA0 which is an arc power setting, I could not understand why it is 1)
- 0: no fading is ongoing
- 1: reset state is present
- 0: it has short address
- 0: no power failure ( it received RESET command and arc power control command)
the timing is a little bit bad but I have an ad-hoc method to read it successfully anyway. I get the same reply if the lamp unit exist or if I remove the lamp unit on the run-time.
I wonder why DALI do not generate a failure if the lamp unit does not exist (or removed on the run-time)? What cases are defined as failure? I wanted to test that I can detect the lamp failures (without breaking my lamp unit:), so that I am disconnecting the lamp unit. Is it a wrong thinking? If it is so, how should I have tested it so that I can get the lamp failure report from the DALI slave?
What command (or command sequence) is the most reliable way to detect a broken LED lamp (by querying from DALI LED control gear)?
I feel like I cause to take one's time to get a reply. I would be happily give 100 bounty for a satisfactory answer to show my gratitude.
