I have interfaced SIM300 Gsm module with lpc2468 through UART. My main motive is to send SMS when some special sequence run. Now my requirement is that I should send the same messages to two numbers.
Is it possible to send message to multiple numbers giving AT+CMGS command only once?
Right now I do:
AT+CMGF=1 //TEXT MODE
AT+CSCS ="GSM" //SET GSM MODE
AT+CMGS="+9198........." //FOR FIRST NUMBER
> HELLO
CTRL+Z
AT+CMGS="+91981........" //FOR SECOND NUMBER
> HELLO
CTRL+Z
Is something like this possible
AT+CMGS="+9198........","+91981........."
>HELLO
CTRL+Z
The parameter that contains the number is the GSM 03.40 destination address and only allows a single value. You'll need to loop through the list of recipients and send multiple commands to send multiple messages. If you check GSM 03.40 on Wikipedia you'll see the TP-DA destination address only allows 2-12 octets.
| improve this answer | |
