Choose a frequency \$f_0\$.We have to project a circuit such as:
  1. all the \$f \ge 10f_0\$ can pass without attenuation
  2. all the \$f \le \frac{1}{10} f_0\$ pass with an attenuation of a factor of 10.
The solution is giving by
but I can't understand why. Could you help me?
In this instance, think of the capacitor as a frequency-dependent resistor.
At high frequencies, you can think of it as a dead short relative to the fixed resistance. In that case, the input is simply connected to the output, so the gain is 1.
At low frequencies, the capacitor is a open circuit. Now you only have the two resistors forming a voltage divider with a gain of 1/11. Whoever said this had a low frequency gain of 1/10 was wrong, unless they consider 1/11 within their error margin. Note that the gain of the voltage divider is:
  gain = R / (10R + R) = R / 11R = 1/11
To find the crossover frequency of a R-C filter, you set the impedance magnitude of the capacitor equal to the resistance:
  R = 1 / (2πfC)
When f is in units of Hz, C in Farads, then R is in Ohms.
  • \$\begingroup\$ Could you explain me why, at low frequencies, the capacitor is an open circuit? \$\endgroup\$ – sunrise Jul 3 '13 at 12:57
  • \$\begingroup\$ If I consider a frequency like 10 Hz and a C=47nF, according to \$Z=\frac{1}{\omega * C}\$, I obtain a very heigh impedence.. where am I wronging? Many thanks for your help! \$\endgroup\$ – sunrise Jul 3 '13 at 13:09
  • \$\begingroup\$ @sunri: Look at the equation I showed for the impedance magnitude of a capacitor. R becomes infinite as C goes to 0. \$\endgroup\$ – Olin Lathrop Jul 3 '13 at 13:10
  • \$\begingroup\$ "Open circuit" means that the resistence is infinite.. isn't it? \$\endgroup\$ – sunrise Jul 3 '13 at 13:20
  • \$\begingroup\$ If, at low frequencies, the capacitor is like a very high resistor, the current doesn't pass through it and passes through the two resistors. Is this step correct? Now, I know that if I consider a "normal" high pass filter, all low frequencies are attenuated, sometimes they are attenuated a lot. Is this strong attenuation due to the fact that a very little current passes through the capacitor? And, in our circuit, is the attenuation of a factor of 10 due to the fact that much more current passes through the resistor R1=10R than the current that passes through the capacitor? \$\endgroup\$ – sunrise Jul 3 '13 at 13:37
