This is the program for blinking Red LED on port P1.0 on MSP430 Launchpad
#include <msp430.h>
int main(void) {
    WDTCTL = WDTPW + WDTHOLD;       // Stop watchdog timer
    P1DIR |= 0x01;                  // Set P1.0 to output direction
    for(;;) {
        volatile unsigned int i;    // volatile to prevent optimization
        P1OUT ^= 0x01;              // Toggle P1.0 using exclusive-OR
        i = 4000;                   // SW Delay
        do i--;
        while(i != 0);
This was working fine except lots of warnings similar to the following:
Interrupt vector "COMPARATORA" does not have an interrupt handler routine. lnk_msp430g2553.cmd /LEDBlinking line 88 C/C++ Problem
I got some help from the IDE only: At least one of the ISR vector was detected to be un-initialzed.
When I added the following lines of code, the warnings disappeared.
/* Initialize non-used ISR vectors with a trap function */
#pragma vector=PORT2_VECTOR
#pragma vector=PORT1_VECTOR
#pragma vector=TIMER1_A1_VECTOR
#pragma vector=TIMER1_A0_VECTOR
#pragma vector=TIMER0_A1_VECTOR
#pragma vector=TIMER0_A0_VECTOR
#pragma vector=ADC10_VECTOR
#pragma vector=USCIAB0TX_VECTOR
#pragma vector=WDT_VECTOR
#pragma vector=USCIAB0RX_VECTOR
#pragma vector=NMI_VECTOR
#pragma vector=COMPARATORA_VECTOR
__interrupt void ISR_trap(void)
pragma I know is a compiler directive that tells to do something explicitly. But what exactly is happening here I am not able to understand. Also the function ISR_trap(void) doing here? When I removed this function, I saw again those warnings.
Here's how an interrupt works:
When a certain event happens (the one that triggers the corresponding interrupt) the processor stops what it's doing, saves it's current execution point (the program counter), and starts executing the interrupt handler. Usually the last instruction of an interrupt handler is a special instruction that tells the processor to continue execution from the point it saved before entering the interrupt.
To execute the interrupt handler the processor needs to know where it is.
Often this is done like this: each interrupt has a corresponding address in the program memory and the processors starts executing instructions from there, usually these addresses are at the very start of program memory. Because one instruction is usually not enough for an interrupt handler, the instruction is usually a jmp to the actual handler. This creates a problem: if at the start of program memory you have a bunch of jmp's that go to the corresponding interrupt handlers, then the first instruction the processor sees after power-on is a jmp to the first interrupt handler and it will execute that instead of the main program. Because of this the very first instruction in program memory is usually a jmp to the main program code (you can think of a reset as a special type of interrupt you don't return from), and the jmp's to the interrupt handlers follows it.
Therefore, the compiled program in program memory can be disassembled to something like this:
jmp main_program
jmp isr_1
jmp isr_2
isr_1:
reti
isr_2:
reti
main_program:
The assembler code
somewhere:
is a label. It doesn't get converted into binary code, but the assembler remembers the address at which "somewhere" was placed and replaces any mention of it in the assembler listing with that address. So when the assembler sees this:
    jmp somewhere
somewhere:
    some_instrunction
it remembers the address at which "some_instrunction" was placed and compiles "jmp somewhere" to the binary code "jmp_opcode address_of_some_instrunction".
So what does all of this have to do with the compiler warning you're getting?
The compiler is warning that you haven't assigned the interrupt handlers for the events it's warning about. What the compiler does with this is compiler dependent. It might not generate an interrupt table at all (if interrupts aren't enabled, this won't be a problem, if they are the interrupt will jump to somewhere close to the start of your program, but not quite (the exact position will depend on the interrupt address)), it might place reti instead of jmps so if the interrupt is triggered it immediately returns, it might have its own emergency interrupt handler that halts processor execution.
What does "#pragma vector=event" and "__interrupt void function_name()" do?
"__interrupt" tells the compiler that the function following is actually an interrupt handler, so it can't have any arguments, instead of a ret instruction, the function ends with a reti, and some over things like what registers are saved on the stack, etc.
"#pragma vector=event" tells the compiler the interrupt to what event the function following is and to use the address of that function as an argument for the jmp instruction placed at the address of the "event" interrupt.
So the code you wrote that stopped the warnings is a handler for all the events in the #pragmas written.
When you removed the function itself, you basically told the compiler "the following function is an interrupt handler" but didn't give it a function. So the compiler still doesn't have an interrupt handler. Placing a #pragma like this (without the function it's talking about) is dangerous, because you might like start writing something else and that something else will become an interrupt handler. Even more painful would be to place such a #pragma in an ".h" file (or is the scope of a #pragma only one file?).
Are those warnings a problem?
You need to make sure that you have defined interrupt handler for all the interrupts that are enabled. Usually there is a global_enable_interrupts bit that needs to be set for interrupts to works at all and an enable bit per each possible interrupt. Usually the enable bit of each interrupt is in the setup registers of the peripheral module (uart, timer, etc...) that triggers that interrupt. Also, the interrupt_triggered bits of the peripheral module usually set / clear even when the interrupts themselves are disabled (for example, the uart has a byte_recieved interrupt, the interrupt is disabled, but that bit can be checked by the software to see if a byte has been received, this can be used to receive bytes with polling).
Another thing to keep in mind is the NMI (non maskable interrupt), you need to think about what will happen if / when it gets triggered.
| improve this answer | |
  • \$\begingroup\$ I appreciate your efforts in this detail answer, but I could not get : "This raises a question: if the interrupt handler addresses are at the start of the program memory, then how can the main program actually start?" Could you plz rephrase these lines ? also in your 5th line is it entering the interupt or exiting the interupt? \$\endgroup\$ – gpuguy Jul 5 '13 at 9:18
A microcontroller usually has multiple interrupts - internal ones (like an internal timer) and external ones (for things like button presses, receiving data, etc).
An interrupt handler is the code that is executed when a certain interrupt is triggered. For example, you'd connect a button to an external interrupt line and then write a handler that toggles an output every time the button is pressed.
The warnings are simply telling you that you haven't defined handlers for all available interrupts, and therefore the uC doesn't know what to do when they happen (and therefore will do nothing). This may not be what you want, and so the compiler tells you about it.
If you want the compiler to stop complaining, you have to tell it explicitly that you want nothing to happen for those interrupts (and that's what the empty ISR_trap is doing there). The pragmas tell the compiler which interrupts the handler applies to.
Be careful not to accidentally ignore any interrupts that you need in this way.
