In Eagle Cad 6.4 is there a way to toggle between "real" and "outline" mode? The Ratsnest command will pour and display the flood fill. I simply want to return the display back to way it was prior,outline for easier visibility - Back and Forth.
I see that "ripup *" will do it. but it will also ripup the routes. In other CAD's one can simply redraw and the pour is simply omitted. I also see "SET POLYGON_RATSNEST OFF" will prevent the pours from filling. But does not un-draws the fills.
At the moment the only way I can see is to close and reopen the file.
    \$\begingroup\$ I only know Eagle 5.x, but isn't performing a ripup by clicking on the edge of the filled polygon doing the trick? \$\endgroup\$
    – Rev
    Jul 4, 2013 at 18:24
  • \$\begingroup\$ @Rev1.0 That works in Eagle 6 too. \$\endgroup\$
    – us2012
  • \$\begingroup\$ @us2012: Thanks for the confirmation, i posted this as an answer. \$\endgroup\$
    – Rev
    Jul 4, 2013 at 18:32
Perform a partial rip-up by clicking on the edge/perimeter of the filled polygon. This will just "clear" the polygon and leave everything else from the signal intact.
"ripup @;" will clear the copper pour
