Is there any special tool used to adjust trimmer potentiometers?
I have some similar to the one on the picture:
PIHER PT10LV trimmer potentiometer
I've tried using small slot, Phillips and Pozidriv screwdrivers, but they all don't seem to fit nicely giving me impression that there is some special tool used to adjust trimmer potentiometers.
If there isn't any special tool, what has proven to work well for you?
  • \$\begingroup\$ 'Scope probes often come with a small plastic screwdriver. Do yours fit? \$\endgroup\$ – tyblu Dec 4 '10 at 21:20
  • \$\begingroup\$ @tyblu Unfortunately, I'm still using my sound as oscilloscope. Once I get a real one, I'll be sure to report here, but that could take a year or two. \$\endgroup\$ – AndrejaKo Dec 4 '10 at 23:12
13
Goot Zirconia Cross Screwdriver for Electronics DIY
This is a very interesting key for those who working with radio, or anything else that requires adjustment in bobbins, trimpots, trimmers and the like.
Its tip is a type of a white ceramic (the package says "zirconia" but it is actually Zirconium dioxide), which gives a high stiffness and does not change the tuning coils because it is not obviously of magnetic material.
alt text
Source (Portuguese): http://badulaquesdachina.blogspot.com/2010/03/chave-de-alinhamento-de-ceramica.html
  • \$\begingroup\$ I think I'm going to take one of these. \$\endgroup\$ – AndrejaKo Dec 4 '10 at 23:14
  • \$\begingroup\$ Me too. It's very cheap. \$\endgroup\$ – Daniel Grillo Dec 10 '10 at 12:28
The only time you need something more than a small screwdriver is on things which have a protruding screw like multiturn pots and trimmer caps, as standard screwdrivers slip off too easily, especially when doing multiple turns - a proper trim tool with recessed blade works a lot better for these. e.g. http://uk.farnell.com/vishay-spectrol/acctritob308-t000/trimming-tool/dp/145507
recessed blade one end, protruding blade on other
Just use a small flat-head screwdriver.
    \$\begingroup\$ As long as it's not a finicky high frequency circuit already touchy about stray inductance and capacitance. \$\endgroup\$ – DarenW Dec 4 '10 at 4:03
    \$\begingroup\$ You wouldn't use that pot in a HF application, anyways. \$\endgroup\$ – Connor Wolf Dec 4 '10 at 9:28
They do make tools like this one, but most people use a small screw driver. The only real advantage of the special tools is that they are often nonconductive plastic.
I have found that the screwdrivers in glasses repair kits work very well for me.
I think the thing is, you want something that isn't magnetic or conductive to adjust the device. Maybe that isn't a big deal for potentiometers, and a regular metallic screwdriver works ok (in my experience, at least) but for tunable inductors or tuned circuits I would think it might be an an issue. Many screwdrivers, even the small ones, are easily magnetized.
In a kit from school I got a small plastic "screwdriver" for this purpose. O Engenheiro's answer describes another device that does something similar.
    \$\begingroup\$ Being born back in the 1960s and a tinkerer of radios from a young age, I'm brainwashed to use only plastic tweaker tools for inductors, and by irrational extension, only plastic for other adjustable parts. But if I don't have a plastic screwdriver handy, the ordinary metal kind will do for trimpots. \$\endgroup\$ – DarenW Dec 4 '10 at 4:00
While at first sight they may look that way, trimmer potmeters are not meant to be trimmed with a cruciform screwdriver like a Phillips or Pozidriv. What appears to be a cross is actually a slot with an arrow in it, which points to the position of the wiper.
So simply use a small flat-head screwdriver, like one from a jeweler's set.
