-6
When distance between the plates is increased, what will happen to the value of the capacitance. (a) Increases (b) decreases
  • 5
    \$\begingroup\$ Before coming here what have you done to find your answer? \$\endgroup\$
    Jul 7, 2013 at 10:27
    \$\begingroup\$ Do your own homework. \$\endgroup\$ Jul 7, 2013 at 12:13
From Wikipedia:
In a parallel plate capacitor, capacitance is directly proportional to the surface area of the conductor plates and inversely proportional to the separation distance between the plates.
parallel plate capacitance formula
where C is the capacitance; A is the area of overlap of the two plates; εr is the relative static permittivity (sometimes called the dielectric constant) of the material between the plates (for a vacuum, εr = 1); ε0 is the electric constant (ε0 ≈ 8.854×10−12 F m–1); and d is the separation between the plates.
